Author Topic: Duplicate tags  (Read 4050 times)
novikovigor
Duplicate tags
« on: June 18, 2013, 07:06:57 pm »
Hello! There is another problem.
I write transformation template, and there is an attribute, that has several tagged values:
Property => Olga
Property => Helga
If I check
%if attTag:"Property" == "Helga"% it returns false.
I guess "Helga" is overriden by "Olga"
So how can I check that there is "Helga" property value in tagged values?
Re: Duplicate tags
« Reply #1 on: June 19, 2013, 08:27:31 am »
Code/transform templates will only get the value for one tagged value with any given name. (ie. You can't do it in the templates)
novikovigor
Re: Duplicate tags
« Reply #2 on: June 20, 2013, 05:39:30 pm »
Thank you, Simon.
novikovigor
Re: Duplicate tags
« Reply #3 on: June 21, 2013, 03:02:33 am »
I'm sorry but I have a trouble.
I can't continue to work, because I need to define all class attributes that have "Property=>Helga" in tagged values including duplicate tags. It's no matter how to define these attributes. Maybe there is auto-replacement "Property=>Helga" into "Helga=>Yes" or any other way that excludes necessity to edit duplicate tags manually? Maybe there is settings?
Ultimately I must define all the attributes, that had "Property=>Helga" tags including duplicate tags.
« Last Edit: June 21, 2013, 03:03:44 am by novikovigor »
AndyJ
  • It's only a model
Re: Duplicate tags
« Reply #4 on: June 21, 2013, 09:00:36 am »
Well... you could export everything to a .csv
Open the .csv in an editor or spreadsheet program
Search & Replace
Import the .csv back into the model.
If you have a lot of tags to change, this may help.
Please bear in mind that I haven't used this method for tagged values, but frequently use this method for other attributes.
Re: Duplicate tags
« Reply #5 on: June 21, 2013, 04:08:42 pm »
Or you write a small add-in/script, to change them over, or use my Simple VBA Excel to EA Importer as a basis to set the tagged values.
I would not recommend to try and change it all in the database directly. Too much chance you miss something and corrupt your model.
novikovigor
Re: Duplicate tags
« Reply #6 on: June 21, 2013, 08:09:30 pm »
Thanks! I've resolved this problem thanks to your advices by executing export/edit/import to xmi format.
AND IT WORKS!!! I'm happy!
