Author Topic: EAUml stereotype shape  (Read 3922 times)
Toth, Istvan Zoltan
« on: June 22, 2013, 09:08:44 pm »
I would like to use the <<worker>> stereotype on a class having the stereotype-less class appearance. (Default is the person inside the circle).
Is there a way to do this? I've tried to change "Override Appearance" under Setting / UML Types to None but it had no effect (setting the color strangely works).
Thank you,
Kind regards,
Istvan
Re: EAUml stereotype shape
« Reply #1 on: June 22, 2013, 09:23:56 pm »
I don't understand what you want to do.
Toth, Istvan Zoltan
« Reply #2 on: June 22, 2013, 09:46:24 pm »
I have a simple UML class on a Class diagram.
I change the stereotype to worker, class shape changes.
I want to avoid the class shape change.
I
« Reply #3 on: June 22, 2013, 10:16:22 pm »
I see. For UC there is an option Advanced/Use Rectangular Notation (also for some other elements). But obviously not in that case.
Try diagram properties Elements/Use Stereotype Icons
Toth, Istvan Zoltan
« Reply #4 on: June 22, 2013, 10:32:42 pm »
Diagram Properties / Element / Use Stereotype Icons worked well.
Thank you,
I
