Author Topic: Insert Related N-ary Associations - version 10  (Read 10020 times)
Re: Insert Related N-ary Associations - version 10
« Reply #15 on: June 17, 2013, 08:40:00 pm »
You should send also a feature request regarding visibility of the association since you have a use case where it's needed to actually see that element.
mitchell.boro
« Reply #16 on: June 26, 2013, 07:11:17 pm »
wrt the drag and drop issue, the response from Sparx is that it is a bug and:
"It appears the issue is related to EA's lazy loading feature.  If you
set the "Tools | Options | General | File Loading Strategy" option to
"Preload Entire Model" then the drag/drop appears to work as expected."
« Reply #17 on: June 26, 2013, 07:54:27 pm »
I guess setting this option isn't worth while since it will slow down the initial model load too much. YMMV
