Author Topic: Relationship Matrix - save as file type  (Read 4171 times)
cms
« on: June 17, 2013, 06:16:36 pm »
I want to embed a relationship matrix diagram into a report, but the options provided are not appropriate.  I have tried to amend the template to use the Relationship Matrix fields, but this doesn't import the image (even though I have selected Matrix.Image).   Is there a way of embedding the diagram or producing a pdf?
Dermot
Re: Relationship Matrix - save as file type
« Reply #1 on: June 18, 2013, 02:10:28 pm »
I  assume you have you set the template to include:
package >
relationship matrix >
{Matrix.Image}
< relationship matrix
This should return a Matrix profile that you have saved in the Resources area - have you checked this was saved?
Alternatively you can save the RM as an image - store it in a Element or Package's Linked Document - then use the Linked Document section to report this.
cms
« Reply #2 on: June 18, 2013, 06:28:07 pm »
Thanks for the reply.  My template does now work (although the image is tiny!).  I'll look at the other options for saving the image separately.
Graham
« Reply #3 on: June 24, 2013, 08:56:07 pm »
Hi there
I have a similar problem. I've been able to add a relationship matrix to a document but can only get it to display one matrix.
However, if I have two matrices (e.g. use cases to requirements and use cases to business rules) only the first is displayed in the document. Both matrices are saved as profiles in my resource browser.
« Reply #4 on: June 25, 2013, 08:40:20 am »
Yes, the feature was only designed to include one.
« Last Edit: June 25, 2013, 08:40:46 am by simonm »
Graham_Moir
« Reply #5 on: June 27, 2013, 07:50:31 pm »
Which is a bit of a constraint wouldn't you say?
