Author Topic: Set label visibility for all associations  (Read 2872 times)
okami
« on: June 28, 2013, 09:02:41 pm »
I wonder if there is an option to set the same label visibility for all associations in a diagram in one step. e.g i want to disable the "Source Top Label" and "Target Top Label".
With the "Set Label Visibility"-option from the context menu i can set it for only for one element. Where can i set it global for the diagram ?
Thanks in advance!
Nabil
    • View My LinkedIn Profile Here
Re: Set label visibility for all associations
« Reply #1 on: July 01, 2013, 08:23:22 pm »
You can hide all connectors labels in a diagram using , Diagram Context menu | Properties | Connectors tab| Suppress all connector labels.
In case, if you want to hide specific "source top label" and "target top label" for an entire diagram, you may have to write script  :)
Nabil
