Author Topic: Reference table/class name in alias for DDL  (Read 3209 times)
dj-obi
« on: July 10, 2013, 06:25:55 pm »
we just introduced Enterprise Architect 10 as our new database design tool and I do have a question regarding the alias field available for tables/classes.
I’m planning to use the alias to add the database and schema name for the DDL generation.
Is it possible to reference the table/class name dynamically, so I don’t have to copy the value from the “Name” field.
Otherwise, the alias may not get updated when the table name changes.
I’m looking for a placeholder that represents the table/class name which is automatically updated during the DDL-generation.
For example I would expect the DDL-generator to use the following information:
Alias: MyDatabase.MySchema.<Name>
in order to generate this script:
CREATE TABLE MyDatabase.MySchema.MyTable
Does such a placeholder exist?
If yes, how is it called?
Your support is much appreciated!
Thanks & Regards,
Mike
« Last Edit: July 10, 2013, 06:26:30 pm by dj-obi »
Dermot
dj-obi
Re: Reference table/class name in alias for DDL
« Reply #2 on: July 11, 2013, 05:40:35 pm »
Thanks a lot for your reply!
Unfortunately, tagged values or owner are not really the solution I'm looking for.
Apart from the additional hassle to maintain this information, I don't see a knock on effect on my DDL.
Maybe my example was misleading!
I don't want to hardcode the database and schema names in my tables/DDL. I'm using placeholders in the alias which are exported into the DDL and then get filled by my database installation.
For example:
$(dbname).$(dbschema).<TABLE-NAME>
Now I'm looking for a way to reference the table name from the "Name" property (represented in my example by <TABLE-NAME>).
This way I could use the same alias string for all tables/classes and I don't have to worry about maintaining it.
Thanks & Regards,
Mike
