Author Topic: C Code Generation typedef struct  (Read 3334 times)
D. Schmid
« on: July 11, 2013, 09:45:43 pm »
Hi @ all,
I've got a Problem regarding the Code Generation of C-Code
The following Class Combination will get me follwing Code Fragment
| <<typedef>> |                   |  <<struct>>  |
|     Class1      |----------|>  |  Class2         |
                                         | Attr1: int      |
Sorry for the crude graphics but I don't have a space available where I can put a screenshot right now.
The connection between the 2 Classes is a Generalization. This will produce the follwoing code:
struct Class2
 int Attr1;
typedef Class2 Class1;
Since this Code will not compile I'm searching for the right command to add the missing
typedef struct Class2 Class1;
(Sorry nesting color inside Code obviously doesn't work here  ;D)
Can anyone point me in the right direction because all I've found up to this point is that somewhere in the "Linked Class Base" Template before the %linkParentName% I should have %linkParentStereotype% but this Attribute doesn't exist  :'(.
Any help is appreciated
Best regards
Dominik
Using EA 12 (1215) | C | C++ | C# | Java | UML 2
g.makulik
Re: C Code Generation typedef struct
« Reply #1 on: July 12, 2013, 07:49:03 am »
Hi Dominik,
I have some draft tutorial how to handle c code generation with additional requirements. Send me a PN with your eMail-Address and I can supply what I have about this subject so far.
Best regards,
Günther
« Last Edit: July 12, 2013, 07:49:50 am by g.makulik »
