Author Topic: Other relationship than Generalization / Specializ  (Read 3083 times)
Michel777
« on: July 27, 2013, 06:30:26 pm »
by creating relationships on the model are offered two kinds of them: Generalization / Specialization. Other Relationships can only set after creating and by choosing "Advaced / Change type" .
Is there a more comfortable way to do it  ? Perhaps to cusomize the menu ?
mcihel
« Last Edit: July 27, 2013, 08:06:29 pm by michel777 »
Re: Other relationship than Generalization / Spezi
« Reply #1 on: July 27, 2013, 07:32:30 pm »
Which diagram type? Quick Linker or Toolbox?
Michel777
« Reply #2 on: July 27, 2013, 07:35:12 pm »
Requirements, Actors, Use Cases,... / Quick linker.
« Last Edit: July 27, 2013, 08:07:19 pm by michel777 »
Re: Other relationship than Generalization / Speci
« Reply #3 on: July 27, 2013, 08:20:05 pm »
The quick linker is pre-defined per diagram type. The default requirements diagram from Sparx MDG has just those few relations. You can either design your own requirements diagrams with QL and toolbox with a MDG (which I'd recommend, but it's a bit of work). You can access all other relations via the toolbox: hit the space bar and navigate to the desired toolbox/relation. Then you can click drag from the source and drop on the target element (the mouse icon changes to a hand when moved). You can repeat the connector with F3.
