Author Topic: Save relationship matrix for reuse  (Read 7552 times)
Michel777
« on: July 27, 2013, 06:09:15 pm »
how to save a relationship matrix in prior to show the actual relationships / to be able to show the relationships with "one click"?
Michel
Re: Save relationship matrix for reuse
« Reply #1 on: July 27, 2013, 07:30:47 pm »
Options/Profiles/Save as... and later using the Profile drop down.
Michel777
« Reply #2 on: July 27, 2013, 07:34:10 pm »
But how to publish it to "HTML users" ?
« Reply #3 on: July 27, 2013, 08:15:30 pm »
It would help if you post your COMPLETE question right in the first post.
You can't do that.
Michel777
« Reply #4 on: July 27, 2013, 08:50:20 pm »
we have the following relationships
goals - features
features - requirements
requirements - use cases
all the 3 relationship matrixs should be accesed with one click, like a diagram, that means the matrixs are storde in the model and click on the matrix  gives us the actual relationships (no snapshot from the past, linke png.)
Michel
Michel777
« Reply #5 on: July 27, 2013, 10:31:01 pm »
solved, partially: to place Hyperlink (Type = Matrix, Matrixprofile = the saved referenc Matrix) on a diagramm.
Still open: how to store / to show the Hyperlink in the Project browser ?
Michel
« Last Edit: July 27, 2013, 10:32:50 pm by michel777 »
« Reply #6 on: July 27, 2013, 11:55:50 pm »
The project browser can only display element/packages. Nothing else. You might consider using View/Model Views.
« Last Edit: May 04, 2021, 08:56:23 pm by qwerty »
bubble
« Reply #7 on: May 04, 2021, 08:54:34 pm »
i know, the topic is old but for those who still wants to know how do create a relationship matrix as an element in the project browser.
1. create a diagram.
2. add an artifact element.
3. set the stereotype of this element to EAUML::EAMatrixSpecification
4. you will be asked to set the profile of your relationship matrix, which you do.
5. in the open matrix you set all your relationships between the objects you chose in the profile setting
6. set a proper name for your matrix
7. save the current matrix under options->profiles->update current profile
8. optionally you can delete the diagram on which you have placed the matrix element with the matrix element left in the project browser package
your matrix is saved as a matrix profile. you can open it by clicking on the maxtrix element in the project browser OR you can open an empty relationship matrix and load your profile in the pull down box "profile" (thats why you needed a proper name for your matrix)
