Author Topic: Sparx EA Help - Can you draw a straight line?  (Read 13846 times)
JonathanSmithey
« on: July 20, 2013, 01:17:00 am »
I'm new to Sparx EA and I'm liking what I'm seeing, but I'm struggling to do what I feel is a basic task.
I want to draw a straight line on a diagram that ISN'T connected to any elements.  I want to show some boundaries on a diagram, but the boundaries element or the swimlane function do not do what I need.  Can this be done?
I've gotten around this by using the "fork / join" element to show a vertical line, but wondered if there's a easier way to do this as this wouldn't work if I wanted to draw a non-connected diagonal line.
Any advice will be welcome
Re: Sparx EA Help - Can you draw a straight line?
« Reply #1 on: July 20, 2013, 08:57:25 am »
EA is NOT Visio. You can mimic a straight line by a narrow boundary. Also (IIRC) some profiles have something like straight lines (was it hand drawn or presentation? Can't remember; check the MDGs).
philchudley
« Reply #2 on: July 21, 2013, 02:48:39 am »
The toolbox you want is [highlight]User Interface[/highlight]
This has [highlight]straight lines vertical or horizontal[/highlight]
As these are elements (with the usual properties) you can use connectors to/from and also realise requirements if you need to.
Cheers
Phil
Models are great!
JonathanSmithey
« Reply #3 on: July 22, 2013, 11:32:23 pm »
Thank you for your help.
I've now upgraded my version of EA and I do now have those elements in the User Interface toolbox (they don't exist in 7.2 which I was using).
Yes, I am aware that EA is not Visio but as you can annotate using plain test, I wondered if there was a function to also draw lines for the same purpose so that I could share the output diagrams with "business" users without having to re-draw them elsewhere.  They often require more user friendly pictures to make complex IT architecture seem simpler.
« Reply #4 on: July 22, 2013, 11:36:38 pm »
I see the arguments for having better drawing utilities in EA. I however have two arguments against it: first the drawings shall be UML compliant and second each extra feature will increase the price of EA and/or make it more unstable. Depending from where you look either argument has its weight. YMMV
JonathanSmithey
« Reply #5 on: July 23, 2013, 12:54:48 am »
yes, I see your point  :)
« Reply #6 on: July 31, 2013, 11:17:10 am »
