Author Topic: How to add images to requirements  (Read 3711 times)
Lars Frantzen
« on: August 01, 2013, 05:31:07 pm »
I need to add/associate images to requirements (e.g. a screenshot). I wonder what is the best way to do so. The images must also appear in the generated documentation when the requirement is mentioned.
I tried several things, like adding an association between the requirement and the boundary storing the image. But I did not find a way to print out the image in the generated documentation then.
Currently I solve it like this:
For each requirement with images I make a dedicated custom diagram only holding the image(s) boundaries. This diagram is then moved in the project browser so that it becomes a leaf of the requirement it belongs to. By so doing the generated report will print the diagram with the images after it encounters the requirement.
But probably/hopefully there is a better way to do so?!
Thanks and cheers,
Lars
Re: How to add images to requirements
« Reply #1 on: August 01, 2013, 05:45:24 pm »
Lars,
We use "linked document" for things like that.
Lars Frantzen
« Reply #2 on: August 01, 2013, 05:57:25 pm »
Hi Geert,
thanks, I did not think of the obvious, that works nicely.
Thanks again,
cheers,
Lars
