Author Topic: How to install EA based on MS SQL ?  (Read 3243 times)
Michel777
« on: August 03, 2013, 05:48:51 pm »
I've installed EA several times on my laptop, but I can not rememeber if I was asked for database type (MS Access / MS SQL). I have a corporate floating licence.
How to install EA on the top of  MS SQL (I have the lates Version of MS SQL).
Michel
« Last Edit: August 03, 2013, 05:49:38 pm by michel777 »
Michel777
Re: How to install EA based on MS SQL ?
« Reply #1 on: August 03, 2013, 07:14:30 pm »
"If you plan to use SQL Server, MySQL, PostgreSQL, Access
2007, Sybase Adaptive Server Anywhere or Oracle 9i, 10g or
11g as a model repository, then you must use the Corporate,
Business and Software Engineering, Systems Engineering or
Ultimate editions of Enterprise Architect." from the users guide...
I have the choice between Coporate and Ulimate (licence).
« Last Edit: August 03, 2013, 07:20:31 pm by michel777 »
« Reply #2 on: August 03, 2013, 07:20:19 pm »
There's a SQL script at Sparx' resource page for the according database. Use that to create a schema. Then transfer any existing EAP to that repository.
« Reply #3 on: August 05, 2013, 04:19:15 pm »
There is no difference in the installation of the EA client.
You just connect the client to the database where your model is stored.
