Author Topic: Quality criteria of requirements  (Read 3929 times)
Michel777
« on: August 02, 2013, 07:30:55 am »
I'm surprised, that there is no requirement attributes for quality criteria (clearly correct, complete, consistent, measurable, verifiable, modifiable and traceable).
I've defined eight tagged value pairs (fulfilled= yes/no, notes= explanation in case "not").
Is there a better way for hold the mentioned data ?
Thanks a lot,
Michel
Helmut Ortmann
Re: Quality criteria of requirements
« Reply #1 on: August 02, 2013, 03:53:46 pm »
I would also do it with requirements. That's the porpuse of requirements.
Helmut
Michel777
« Reply #2 on: August 02, 2013, 04:33:14 pm »
On the same way ?
Helmut Ortmann
« Reply #3 on: August 02, 2013, 07:19:20 pm »
I would define a checklist for the different quality criteria. In the requirements I would use the property Status or a tagged value to define a little workflow like:
  • in work
  • ready for review
  • reviewed
  • rejected
Helmut
« Reply #4 on: August 02, 2013, 08:08:18 pm »
Thanks a lot,
Michel
I don't see requirements as attributes of anything. A requirement is an element having attributes on its own and which is related via (stereotyped) dependency to other elements.
« Last Edit: August 02, 2013, 08:08:48 pm by qwerty »
Gary
« Reply #5 on: August 05, 2013, 08:03:24 pm »
Hi Michel
To do what you want, go to Settings->Project Types->General Types
Select the Status tab and add the values you would like to use.
You can then select these values in the Status drop down on the properties page.
A bonus of doing this is that the same types are now available for all elements not just requirements.
Gary
