Author Topic: Error opening EAP file  (Read 14348 times)
K N
« on: August 14, 2013, 09:57:21 am »
Hi
When I am opening eap file, i am getting the following error:
"An Error has occurred: Unrecognized database format 'filepath'"
What could be the reason for this?
KN
Re: Error opening EAP file
« Reply #1 on: August 14, 2013, 10:23:50 am »
What is the file size?
K N
« Reply #2 on: August 14, 2013, 10:27:02 am »
arnd 70 MB.
Aaron B
« Reply #3 on: August 14, 2013, 10:48:22 am »
First thing to try is to enable Jet 4.0.  See:
http://www.sparxsystems.com.au/support/faq/database.html
K N
« Reply #4 on: August 14, 2013, 10:51:34 am »
Hi Aaron
I tried both the options - Jet 4.0 and Repair .eap file.
It gives me  - "operation is not supported for this type"
KN
Aaron B
« Reply #5 on: August 14, 2013, 11:21:38 am »
What is the exact error message and when does it appear?
K N
« Reply #6 on: August 14, 2013, 11:25:36 am »
When I enable Jet 4.0 and restart EA and try to open the file, it gives the same error of "Unrecognizable database format".
Keeping the Jet 4.0 enabled, i tried repairing the eap file then it gives me the error of "operation is not supported for this type"
Aaron B
« Reply #7 on: August 14, 2013, 11:38:39 am »
This could suggest the file is the default Jet 3.5 format, but the problem is that the file has become damaged.
Try disabling the Jet 4.0 option again, then try using the Repair EAP File command.
K N
« Reply #8 on: August 14, 2013, 11:59:11 am »
Thanks Aaron!!
I tried what you suggested - disabling Jet 4.0 and then repair....it gives the same error - "Unrecognized Database Format"
Aaron B
« Reply #9 on: August 14, 2013, 12:04:23 pm »
If possible, please zip up your EAP file and send to [email protected] for further investigation.  If the file is too big to email, perhaps try using DropBox and provide the url instead.
K N
« Reply #10 on: August 14, 2013, 12:59:51 pm »
Sorry Aaron...I cannot share the file as it has company project's sensitive data.
Is there any other way you can help? Like webex or sharing our screens or if you need any screenshots?
Let me know which option is suitable for you
KN
« Reply #11 on: August 14, 2013, 03:49:42 pm »
I believe Aaron was suggesting that because we may be able to correct the issue using MS Access. A webex or similar isn't going to help repair the file.
If you don't have Access, or someone you do trust who has it, or it doesn't work then I hope you do have a recent backup.
« Reply #12 on: August 14, 2013, 07:08:36 pm »
I once got an obfuscation tool from Sparx. But likely that won't work with a damaged EAP?
Have you tried opening with MS Access?
If you open the EAP with Notepad++ you should see
NUL SOH NUL NULStandard Jet DBNUL...
« Last Edit: August 14, 2013, 07:12:10 pm by qwerty »
K N
« Reply #13 on: August 14, 2013, 11:47:17 pm »
@Simon -  ok...what subject line should i write in the email so that its easily understood by you or Aaron to take it from there.
@qwerty - I am trying to open it with Notepad too...its still in process...giving "not responding" ..i think this is because of the file size.
K N
« Reply #14 on: August 14, 2013, 11:53:45 pm »
@qwerty - this is what i got when i tried opening with Notepad++
"NUL SOH NUL NULStandard Jet DBNUL..."
