Author Topic: Including Scenario Alternate Path Join in template  (Read 4103 times)
David Bigsby
« on: August 16, 2013, 07:42:46 am »
Hey there,
I've got a modified user interface template for my project, and am using Scenarios for some elements (e.g., buttons) to specify dynamic behaviour and to create test cases.
A problem I've found is that, while my Alternate Paths get listed in my template, they do not include the "Join" information.
That is, I type this:
  • Step: 3a
  • Path Name: No Matching Organization Found
  • Type: Alternate
  • Join: 5
...but in the RTF there is no field corresponding to "Join" -- there is only:
  • Scenario
  • Type
  • Notes
  • Weight
Any thoughts on how to solve this?
Thanks!
« Last Edit: August 16, 2013, 07:50:04 am by dbigsby »
jfzouain
Re: Including Scenario Alternate Path Join in temp
« Reply #1 on: August 17, 2013, 04:16:01 am »
Hi
Have you added a step to the Alternate?
If not, you always have to have a step in any path in order for the join to work.
After adding the step, set the join correctly, save it and then generate.
You will see it now.
Best regards
Jose Zouain
