Author Topic: Automatically creating diagrams  (Read 4654 times)
andykennelly
« on: August 23, 2013, 12:20:42 am »
I know I can easily import a list of elements using the CSV import function.
And I know I can even create links as part of the import if I use scripting. That would then position me to create diagrams with linked elements when subsequently I drag/drop the elements onto a diagram.
I'm now wondering if it's possible to automatically create those diagrams, e.g. for each folder created during the import a diagram is created with the relevant elements and their links - if this is technically possible, I'm seeing a very complex piece of scripting to make it happen!
Maybe the nearest I can get to this is to manually drag/drop and then use Diagram | Layout Diagram.
Any views? Is this somewhere anybody else has been?
ken.norcross
Re: Automatically creating diagrams
« Reply #1 on: August 23, 2013, 04:12:41 am »
I have used scripts to at least create the diagram and add the items to the diagram. In my case I had many packages with a small number of items in each, so I at least wanted to automate that much.
I still had to manually go into each diagram and resize/relayout so the solution was not ideal.
« Reply #2 on: August 23, 2013, 06:37:15 am »
There's a LayoutDiagram method in the project interface. You might use that as a start.
ken.norcross
« Reply #3 on: August 23, 2013, 11:26:19 am »
Thanks for the pointer!
