Author Topic: DB2 - showing schema names  (Read 2743 times)
realhusker
« on: August 29, 2013, 12:32:48 am »
I am new to EA  (fair warning!).  When I import a database with via ODBC from db2 (unix), how can I display the schema name in the project browser and the diagrams along with the table names?
Re: DB2 - showing schema names
« Reply #1 on: August 29, 2013, 01:07:04 am »
Just rename the folder into which you have imported. With the folder selected click the New Diagram icon and create a class diagram. Then drag all tables onto the diagram and choose auto-layout. You will likely need to do some manual corrections.
P.S. You should drag one table first and select "Options/Use Ctrl..." prior to moving the rest of the tables since EA would ask for each single table how to copy it.
« Last Edit: August 29, 2013, 01:11:57 am by qwerty »
