Author Topic: Synchronize secondary stereotypes  (Read 3136 times)
McMannus
« on: August 29, 2013, 09:29:54 pm »
Version 7.0 - Released (Build 813) - Extended Synch Tagged Values and Constraints command to synchronize secondary stereotypes.
The situation: I have some stereotypes in a toolbox which can be dragged in a diagram. Optionally, more stereotypes existing in my profile (but not in the toolbox) are added to the diagram elements later. If those optional stereotypes change in the profile, I don't see any way to synchronize them in my existing projects. Since they aren't available in the toolbox, the approach right-klick>Synchronize Stereotype doesn't work.
I think it would work if I programmatically delete and reassign the stereotypes, but the quoted release note seems to me like there is a built in solution for that task, because the optional stereotypes are in my opinion exactly these secondary stereotypes.
Thanks for help!
« Last Edit: August 29, 2013, 09:30:40 pm by McMannus »
Re: Synchronize secondary stereotypes
« Reply #1 on: August 29, 2013, 09:54:03 pm »
In V10 you don't need to synch any longer. But for earlier releases you likely need to setup a dummy toolbox for that purpose. I used to call that "Extended".
