Author Topic: ea_guid for tagged value  (Read 3725 times)
novikovigor
« on: September 02, 2013, 10:52:08 pm »
Hello!
I need to create tagged values by SQL insert. ea_guid will be calculated next way:
ea_guid = {ea_guid_for_attribute + "-CONST"}
So, ea-guid for tagged-value will be "{bla-bla-bla-CONST}" if ea_guid for attribute is "{bla-bla-bla}".
Now it works well, but should there be any problems with this calculated guid? Further i'll use this property as flag in model transformation.
Helmut Ortmann
Re: ea_guid for tagged value
« Reply #1 on: September 02, 2013, 11:08:34 pm »
the GUID have to be unique, theoretically worldwide. You can get a GUID by API, tools or http://www.guidgen.com/.
Your workaround may work as long as the generated GUID is unique.
Helmut
novikovigor
« Reply #2 on: September 02, 2013, 11:12:12 pm »
Thank you for quick answer and for link, Helmut!
« Reply #3 on: September 02, 2013, 11:27:31 pm »
Sounds like your guid will be longer than the usual GUID. I don't think that's a good idea since it is stored in EA's database in a column with fixed length. Better replace one part with a fixed string. That's also what EA does with some GUIDs.
novikovigor
« Reply #4 on: September 02, 2013, 11:52:47 pm »
Qwerty, I've solved my problem by generating ea_guid. I will use java API for it.
