Author Topic: BPMN Simulation  (Read 3126 times)
OpenIT Solutions
BPMN Simulation
« on: August 29, 2013, 12:15:57 am »
When running a (BPMN) simulation is it possible to access tagged values associated with an activity. Can this be done using the default simulation approach - which appears to interpret code found in the 'behaviour' tab of diagram elements (?) - in which case can i reference a taged value within as this code is being interpreted ? Whats the syntax ? If it can't be done using this default approach - can it be done using a custom script ?
Either way are there any examples/documents the explain how ? The similation example attached to the recent sparx video on the topic doesn't have this sort of detail....
Jon.
OpenIT Solutions
Re: BPMN Simulation
« Reply #1 on: September 04, 2013, 05:23:08 pm »
FYI from Sparx support the answer appears to be NO. I've requested this as a new feature - would be especially useful in a BPMN simulation as in Sparx a lot of useful info is help in BPMN related elements, activities, events, participatns, pools etc.
