Author Topic: Traceability from/to sequence diagram  (Read 27582 times)
wallyjp
Re: Traceability from/to sequence diagram
« Reply #15 on: September 26, 2013, 04:17:17 pm »
Hi Geert,
Thank you for your concrete advice  ;)
I succeeded to make the clicktrough work !
Thank you again!  :D
But still now I don't know how to crete an interacation as a element from ToolBox although I understand to do it under class on Project Browser pane.
Toolbox does not show 'Interaction' as one element.
What I operate was ToolBox | Click 'more tools' | Select 'interaction', then ToolBox shows Interaction classified elements, e.g., actor, lifline, something like that. but  'Ineraction element' itself does not apear.
Kindly correct my operations above ?
Wally
RoyC
  • Read The Help!
« Reply #16 on: September 26, 2013, 04:34:48 pm »
What release of EA are you working in?
Is there a page in that Interaction toolbox called Additional?
« Last Edit: September 26, 2013, 04:36:28 pm by RoyC »
Best Regards, Roy
wallyjp
« Reply #17 on: September 26, 2013, 04:38:28 pm »
Program version is 10.0.1005( Build: 1005), Corporate/floating edition
RoyC
  • Read The Help!
« Reply #18 on: September 26, 2013, 04:58:03 pm »
Well, as far as I know the Additional page, containing the Interaction element, should be there in the Toolbox in your edition of EA.
Best Regards, Roy
wallyjp
« Reply #19 on: September 26, 2013, 05:11:17 pm »
Where can I find the additonal page of the Toolbox you mentioned below?
---<quoted from RoyC email>---
- Open your diagram.
- In the Diagram Toolbox click on More tools and select UML | Interaction.
- Expand the Additional page of the Toolbox; it contains the Interaction element.
- Drag the element onto your diagram.
VKN
« Reply #20 on: September 26, 2013, 05:17:26 pm »
1. In the Diagram Toolbox click on More tools and select UML | Interaction.
On the Toolbox:
2. Click on the [-] sign to collapse Interaction
3. Click on the [-] sign to collapse 'Interaction Relationships'
4. Click on the
  • sign to expand Additional
wallyjp
« Reply #21 on: September 26, 2013, 09:47:41 pm »
1. In the Diagram Toolbox click on More tools and select UML | Interaction. ->OK confirmed
On the Toolbox:
2. Click on the [-] sign to collapse Interaction   -> OK
3. Click on the [-] sign to collapse 'Interaction Relationships' ->OK
4. Click on the
  • sign to expand Additional -> not appear.  Common is under 'Ineraction Relationships'.
    Toolbox shows like below;
    Toolbox
                             More tools...
    - Interaction
      Actor
      Lifeline
      Boundary
      Control
      Entity
       Fragment
       Endpoint
       Diagram Gate
      State/Continuation
    - Interaction Relationships
      4 kind of arrows
    -Common
       Note, constraint, Text,.....
VKN
« Reply #22 on: September 27, 2013, 09:50:07 am »
4. Click on the
Try this:
Right click on the Interaction page and select 'Set Toolbox Visibility'
Check against the 'Additional' (very next to Interaction) | Click OK.
wallyjp
« Reply #23 on: September 27, 2013, 10:21:14 am »
Hi VKN,
The  'Additonal' is not exist in 'Visible Toolbox Pages' window.
Are there things to become it selectable ?
VKN
« Reply #24 on: September 27, 2013, 10:49:34 am »
Hi VKN,
Sorry. Just realized that you'd need
Program version 10.0.1007( Build: 1007) or higher.
wallyjp
« Reply #25 on: September 27, 2013, 11:02:16 am »
No, Program version is 10.0.1005( Build: 1005),
RoyC
  • Read The Help!
« Reply #26 on: September 27, 2013, 11:14:01 am »
My apologies. It seems that this Additional page and the Interaction icon were added in build 1007 in March of this year. When I looked at the edit date of the topic file, it was old, but if I update a graphic file in the Help it doesn't change the topic edit date, and I have just seen that the graphic file was updated in March.
So, Wally, you are perfectly correct, sane and normal!
You could upgrade to the latest release and get the icon in the toolbox. Otherwise, you can create the Interaction through the Project Browser and drag it onto your diagram.
There is another thing you might try, but I doubt if it will work. On your Interaction diagram, press the Ctrl key and click the mouse. You will get a list of elements and connectors. Does Interaction appear on that list? I think that the list is a direct reflection of the Toolbox, so the element won't be included, but try it anyway.
My apologies again.
Best Regards, Roy
wallyjp
« Reply #27 on: September 27, 2013, 11:28:55 am »
Thanks RoyC for investigation.
Since I can't upgrade without IT guys' approval. I'll create the Interaction through the Project Browser and drag it onto others.
I also tried the latter things you mentioned, but it does not work well.
Anyway, I proceed to work using your former advice.
Thanks Geert, VKN RoyC,KP. ;)
