Author Topic: comparison Concept using sparx  (Read 3750 times)
Teja
« on: September 25, 2013, 02:13:02 am »
Hi, can we compare the two databases and generate the document using sparx. For Example I have two Databases, Source contains 10 tables & destination has 15 tables. Using sprarx can we generate document what are the 5 additional tables that we created in destination point.
Re: comparison Concept using sparx
« Reply #1 on: September 25, 2013, 03:11:22 am »
You can't do such things out-of-the-box. In your case you should move both into one repository (you might create a temp one and ex-import the XMI for both schemas). Then create one ore more diagrams putting tables (and contents of those) side by side.
« Reply #2 on: October 01, 2013, 06:16:59 am »
You're looking at the wrong tool,
try something like http://www.red-gate.com/products/sql-development/sql-compare/
