Author Topic: Searching on custom tagged values  (Read 12782 times)
UrsulaGreen
« on: October 11, 2013, 02:16:38 am »
I've been using the tagged value feature with the requirements elements to store information such as: a customer of a requirement; which srum iteration a requirement is developed in.  Is it possible to then use the search facility to query a specific customer or scrum iteration?  I've looked in the help facility and can't find anything
Re: Searching on custom tagged values
« Reply #1 on: October 11, 2013, 08:51:36 am »
You can create a custom search for tagged values. Use Ctrl-F and the builder. Then create a new search (name it Scrum or whatever) and use the Query Builder. Add a filter which includes your tagged value. You can then use that search from the drop down.
If you are after more (advanced) searches you might consult my Inside book.
« Reply #2 on: October 11, 2013, 04:40:39 pm »
I would use an SQL Search.
Something like:
select c.ea_guid as CLASSGUID,c.object_type as CLASSTYPE,c.name as Name, c.stereotype as Stereotype ,package.name as PackageName ,package_p1.name as PackageLevel1,package_p2.name as PackageLevel2,package_p3.name as PackageLevel3
from (((((t_object c
inner join t_objectproperties op on op.Object_ID = c.Object_ID)
inner join t_package as package on c.package_id = package.package_id)
left join t_package as package_p1 on package_p1.package_id = package.parent_id)
left join t_package as package_p2 on package_p2.package_id = package_p1.parent_id)
left join t_package as package_p3 on package_p3.package_id = package_p2.parent_id)
where op.Property = 'MyTaggedValue'
and op.Value like '<Search Term>'
Replace 'MyTaggedValue' with the name of the tagged value you are searching on.
A bit more info on SQL Searches in this article: Harvesting the power of EA’s SQL searches
