Author Topic: Version 3.10 - Build 485 released  (Read 34917 times)
sparks
« on: April 24, 2002, 04:20:50 am »
Changes and fixes for Build 485
- Added option to Object page of View/Options dialog to not show Object or Message properties dialog automatically when adding new element
- Sequence diagrams now support incremental method invocation (recursion) and the ability for messages to extend the recursive method activation (message context menu)
- Sequence diagrams now support conditional messages (branching) and alternate execution paths
- Fixed bug in Replication engine that caused problems with Access 2002 format projects
- Size of selection rectangle for Synchronization element enlarged and 'hot points' also enlarged
- Added support for XMI 1.0 when exporting model to XML format. XMI export dialog now has a 'XMI 1.0' check box. Check to output UML 1.3 in XMI 1.0 format. Still in beta testing, and does not yet include import support.
- Added Data Types to XMI export (XMI 1.1) plus some slight changes to Rose compatible XMI export
- Modified Import Source Tree function so that Packages are not created if the directory contains no source or no child directory with source
- Support for Windows Metafiles in RTF documents - provides compatibility with Wordpad and other simple RTF editors.
     Use WMF image format and check the Embed image check box in RTF dialog
     EMF format with Embed image checked only works with MS Word and compatible
     Note that editors based on the MS Rich Edit control (Wordpad etc.) do not correctly support text wrapping in table cells
- Fixed C++ bug which affected import/synch of const unsigned datatype attributes
- Added option to Object page of Options dialog to hide <<column>> stereotype in Table type elements
- Improved the way datatype size fields are shown for blank datatypes on the Table Attribute screen
- Additional support for early versions of the Oracle ODBC driver that reported database of 'Oracle'
