Author Topic: HTML Report customizing!  (Read 4192 times)
dwang
« on: October 12, 2013, 12:30:45 am »
Hey,
i need your help and it would be great if someone help me.
My problem is that i want to have a customized HTML report for my ea project.
I already start a default HTML report and if I start the html project on a browser to safe the diagram as a picture there is the wrong filename for the picture.
What do I have to change in the default HTML Template to get automatically the correct name of the object/ diagram?
so I hope someone can help me!
THANKS for any HINTS!  :)
« Last Edit: October 12, 2013, 01:14:39 am by dwang »
Stoppy
Re: HTML Report customizing!
« Reply #1 on: October 14, 2013, 11:37:21 am »
Hi Dwang,
If I understand you correctly, I think you are trying to make use of the GUID with the HTML.
Here is a post on that item: http://www.sparxsystems.com/cgi-bin/yabb/YaBB.cgi?num=1349887357/1#1
Stoppy  :)
Skills: Business Process | Business Analysts | Product Configuration Manager | Business Intelligence
dwang
« Reply #2 on: October 14, 2013, 07:46:12 pm »
Hi Stoppy,
thx for your quick answer!
problem: I want to export my project as a HTML Report and i open the Html report on a browser lika chrome, ie, mozilla. then i right-click on the diagram to safe it as a picture there is a defaultname lika ea1 ea2 ea3....
in that case I want to have a specified name for all diagrams. that means it should be automatically the correct filename
« Last Edit: October 14, 2013, 07:47:33 pm by dwang »
« Reply #3 on: October 15, 2013, 09:09:07 am »
While I understand why you would like files matching the original name of the diagram, that can't be the behavior because EA needs to ensure a unique name. The naming scheme you're seeing is the simplest way to do that.
Stoppy
« Reply #4 on: October 17, 2013, 02:05:06 pm »
Is there a reason you are using the HTML v's the Client?
If it is security reasons, you may want to consider looking at the EA Lite Client.
Stoppy  :)
