Author Topic: Debugger Attach to Process just hangs  (Read 2932 times)
mobendorf
« on: October 18, 2013, 04:47:22 am »
I am trying to do something that I thought would be very simple. Go to analyzer/debugger/attach to process and attach to a running java process (with the EA agent running in that process). But not to be. I don't get a list of processes for literally 5 minutes!! Then, I have to select "Java", since "Microsoft Native" is the default. Guess what, sit back and wait another 5-10 minutes for the process list to refresh. EA shows no CPU usage while it is apparently trying to come up with the process list. I can only hope there is some configuration trick that someone knows about to fix this problem! Anyone?
gokula
Re: Debugger Attach to Process just hangs
« Reply #1 on: March 23, 2017, 01:11:09 am »
Please share me the information if  you are able to generate sequence diagram through debugging.
I am trying to do the same but the Jetty Server is running in remote VM. Please help me.
Thank you in advance
