Author Topic: Tagged value types for profiling  (Read 5029 times)
Michel777
« on: October 18, 2013, 08:42:23 pm »
tagged values [ch8203][ch8203]creating for profile  will be defined as attributes. The system only offers the following types of int, byte, char, double ...
What attributes types should I use for the following types ?
Boolean Const, datetime, memo, enum?
Michel
Re: Tagged value types for profiling
« Reply #1 on: October 18, 2013, 09:08:15 pm »
Try to find the post by Phil Chudley how to include tagged values in a profile.
Michel777
« Reply #2 on: October 18, 2013, 09:36:24 pm »
is not the question how to get the tagged values in the Profile, but how to define it.
I checked all the post of Phil...
Thansk,
Michel
« Reply #3 on: October 18, 2013, 11:58:57 pm »
Check the predefined types for tagged values in the help. That's all what is possible.
Michel777
« Reply #4 on: October 19, 2013, 12:53:08 am »
no problem with them, i know all the types in this list.  I'm searching for corresponding types as attribute on the metaclass:
Here: right mouse on the Element, Features & Propterties, Attributes, Type.
Michel
« Reply #5 on: October 19, 2013, 08:14:59 am »
I guess that all you can add are those you will be presented when using "Edit with profile helper/Tagged Values/Add specialized tagged value". There was some way to define a tagged value with a predefined type and use that for a TV in a profile. For that it was put in the TV list of MDG and could ten be used later. But with V10 they changed the way TVs are used in profiles. So I have no idea if that still works (I guess not).
Michel777
« Reply #6 on: October 19, 2013, 08:50:21 pm »
there is a workarund, also mentioned in other post: defining tagged values manually using (***) "Settings", "UML Types" , "Tagged Value Types". They overwrite the tagged value types, they were defined in UML Profile.
Further it is possible the generate the "XML lines " with NDG Technology:
<TaggedValueTypes>
<RefData version="1.0" exporter="EA.25">
<DataSet name="Property Types" table="t_propertytypes" filter="Property='#Property#'">
<DataRow>
<Column name="Notes" value="Type=Memo;"/>
<Column name="Notes" value="Type=DateTime;"/>
<Column name="Notes" value="Type=Boolean;&#xA;Default=False;"/>
But: I could not import the values either with MDG nor with UML Profile.
Therefore a last question: how would it be possible to transfer such tagged values (***)  from one model to an other model ?
Michel
« Reply #7 on: October 20, 2013, 09:45:59 am »
That's what the post from Phil is all about. It's tricky somehow, but after a while I got it work. He posted it somewhat earlier and I replied that I succeeded. Sorry for being too lazy to find the post again. Also I just know that it worked. Actually I don't need it and such would not touch it with pliers unless needed.
Sunshine
  • Its the results that count
« Reply #8 on: October 21, 2013, 02:37:05 pm »
Took me a while but found that post from Phil regarding the solution. For those who need it please find it here
http://www.sparxsystems.com/cgi-bin/yabb/YaBB.cgi?num=1331459874/0#0
Happy to help
« Reply #9 on: October 21, 2013, 07:26:54 pm »
Yeah, exactly! That post should be made sticky :-) At least I will save a bookmark in my browser.
« Last Edit: October 21, 2013, 07:27:32 pm by qwerty »
