Author Topic: Dot Notation  (Read 3083 times)
rothnic
Dot Notation
« on: October 23, 2013, 11:37:00 am »
Does EA support "dot" notation? I cannot find a reference to it.
From the SysML 1.3 specification:
A pathname dot notation can be used to refer
to nested properties within a block hierarchy. This allows a value property (such as an engine displacement) that may be
deeply nested within a containing hierarchy (such as vehicle, power system, engine) to be referenced at the outer
containing level (such as vehicle-level equations).
So a composite diagram or IBD could have a part of:
sb1:Subsystem1, which has a part of
sb2:Subsystem2, which has a part of
sb3:Subsystem3, and so on...
Instead of showing a sb1 rectangle, with a sb2 rectangle inside of it, and a sb3 rectangle inside of it, if you wanted to call out sb3 specifically in the context of the Block's ibd, instead you could have:
sb1.sb2.sb3:Subsystem3
