Author Topic: Requirements  (Read 2876 times)
Tree
Requirements
« on: November 15, 2013, 04:05:22 am »
I am using version 10  (trial) I imported requirements from DOORs.
Why are requirements tab colors not set/changing when I change the status of a requirement?
 The requirements are hierarchical...
I want to pull all the requirements I imported into one diagram quickly… if I have the hierarchy opened in the project browser and select the requirements from the project browser, only the top of the hierarchy is selected and pulled onto the diagram.
Also  the Paste Element dialog shows up for each requirement...cumbersome. Is there any way to stop this dialog from popping up when pasting multiple elements.
Is there anyway to send link/attribute information back t DOORs (i.e. a link to a Use Case or Test case in EA?
I am also using SYSML extension/add on
« Last Edit: November 15, 2013, 04:08:07 am by TeresaPuzzo »
Re: Requirements
« Reply #1 on: November 15, 2013, 07:39:53 am »
Tools/Options/Objects/Show status colors...
Tree
Re: Requirements
« Reply #2 on: November 15, 2013, 07:46:12 am »
Thank you! it Worked... :)
