Author Topic: Automatically Create a Legend  (Read 4255 times)
Brian L
« on: November 15, 2013, 05:41:56 am »
Does anyone know the method call to create a legend from script?
There is no mention on how to create one on Sparx's site nor in the ScriptingEA book.
Thank you for your time,
Brian
Re: Automatically Create a Legend
« Reply #1 on: November 15, 2013, 07:48:12 am »
You need to create a element of type Text. Additionally you need to create an entry in t_xref which is a bit complex. The easiest way: create an empty repository with a single diagram and a single legend. Then go to the query builder and execute
SELECT * FROM t_xrefThe XRefID is an arbitrary GUID. Client is the GUID of the Text element. Description is the meat. Good luck :)
« Last Edit: November 15, 2013, 07:49:47 am by qwerty »
Brian L
« Reply #2 on: November 15, 2013, 08:15:58 am »
Ah. So I create it like I would create a Text element, but I need to add an xref with a modified description.  That is a bit of work.
I only need two different types of legends that will be reused based on diagram type.  The easiest way sounds like creating the legends in a 'holding' diagram and pull them by ID when I need them.
Thank you for the help!
