Author Topic: DB diagram not showing FK links between tables  (Read 3728 times)
bsole
« on: December 08, 2013, 07:16:20 pm »
I'm having an issue with database diagram... I have imported a schema from an external database into a new EA package.  I have then created a new database diagram and dragged table elements onto the diagram however links between the tables for FK constraints etc are not showing.  Is there a way to have these links established automatically or do I need to manually link the EA table elements to match the FKs.... any help would be appreciated.
Dermot
Re: DB diagram not showing FK links between tables
« Reply #1 on: December 09, 2013, 04:05:54 pm »
If you create a Data Model diagram prior to running the import a diagram should be generated for the tables imported. This should include any links based on the keys - see:
http://www.sparxsystems.com/enterprise_architect_user_guide/10/database_engineering/importdatabaseschemafromod.html
