Author Topic: BPMN Subprocess  (Read 8361 times)
Michel777
BPMN Subprocess
« on: December 06, 2013, 06:56:05 am »
how to create a hierarchie of subprocesses and drill down in the prosess-tree ?
Michel
Stoppy
Re: BPMN Subprocess
« Reply #1 on: December 09, 2013, 02:52:57 pm »
Hi Michel,
If I understand you correctly you want to make use of the Composite Elements feature. Go into Help and type "Composite Element" and select Drill Down.
You should end up with a little plus symbol on your element which will drill down to the next diagram.
Stoppy
Skills: Business Process | Business Analysts | Product Configuration Manager | Business Intelligence
Michel777
Re: BPMN Subprocess
« Reply #2 on: December 10, 2013, 08:40:11 am »
Hi Stoppy,
exactly !
Thanks a lot,
Michel
pr1smiley
  • EOD is a Blast!
Re: BPMN Subprocess
« Reply #3 on: December 12, 2013, 03:27:09 am »
Also if you want to have the sub-process imbedded and visible  in the main process click >>New Diagram>> Show Composite Diagram in frame
