Author Topic: EXport class  properties in Excel  (Read 5753 times)
Michel777
« on: December 12, 2013, 09:52:53 am »
we need to export elements, mostly classes with their properties. I know only the export of tagged values, not the properties of classes.
Is there any way export classes and their properties in an excel file ? Perhaps also in the opposite way (import) ?
Thansk a lot,
Michel
« Last Edit: December 12, 2013, 09:53:15 am by michel777 »
JdBAlten
Re: EXport class  properties in Excel
« Reply #1 on: December 12, 2013, 08:48:25 pm »
You could try the CSV import/export feature.
It can be accessed via the package context menu (right-click on the package).
Select menu "Import/Export | CSV Import/Export".
In the window that pops up, you can define a 'Specification' which acts as a 'template' to define the properties of the elements to import or export.
Michel777
« Reply #2 on: December 15, 2013, 12:40:30 am »
Only tagged values are possible to export. No properties of a Class element.
« Reply #3 on: December 16, 2013, 07:15:41 am »
Have you tried the List View? There you can copy/paste properties. The drawback: you need to create a diagram.
« Reply #4 on: December 16, 2013, 06:43:52 pm »
The easiest (without programming an little export utility) is to create an SQL Search containing the data you need. You can then copy/past the results in a text file and open is as a CSV file in excel.
You might also want to look at EADocX. I believe they have an excel export feature as well.
