Author Topic: Bulk change of relationships  (Read 6168 times)
Michel777
« on: October 13, 2013, 07:02:34 am »
there is  70 use cases, 100 components and 500 relationships between them ( trace). Sometimes in both directions .
Question: how to change the relationship  "trace" into "association" ?
Michel
Re: Bulk change of relationships
« Reply #1 on: October 13, 2013, 08:36:39 am »
You should do that with a SQL like
UPDTAE t_connector SET connector_type = "Dependency", stereotype = "trace" WHERE connector_type = associationif it's only relevant associations. Eventually you could export a package with only the elements you want to change, import them in a temp model, run the SQL, and ex-/import them back.
motivatedgorilla
« Reply #2 on: February 13, 2014, 12:15:32 pm »
I thought we couldn't run UPDATE from within Sparx
« Reply #3 on: February 13, 2014, 06:39:39 pm »
You can execute an update statement either directly on the database, or via a script using the hidden operation Repository.Execute(String sqlQuery)
PS. Be careful with that. It is very easy to completely f*ck up your model this way ;D
Sorno
« Reply #4 on: February 15, 2014, 01:42:53 am »
Might not be as neat, but if SQL is too daring - why don't script it?
I have found it very useful to have a basic script that can run through a complete model or certain package and apply some kind of a fix on each element/connector matching some criteria.
If it's a one-time thing the speed of the script dosn't feel like such a big deal.
