Author Topic: RTF output Diagram connector  (Read 5355 times)
LeeD
« on: February 19, 2014, 12:21:29 pm »
Hi
When using the RTF output in EA 10 it's possible and really helpful to be able to output elements and connectors from a diagram in a package rather than having the elements in the package.
Having said that, I can't see a way to include the source and target element names in the output as I can if the elements were referenced directly and not through the diagram? Is there any way to do that?
Cheers
Lee
« Last Edit: February 19, 2014, 12:21:54 pm by LeeD »
motivatedgorilla
Re: RTF output Diagram connector
« Reply #1 on: February 19, 2014, 12:23:43 pm »
Do you mean to say you are unable to output the target and source elements?
LeeD
« Reply #2 on: February 19, 2014, 12:29:06 pm »
I can output the elements but not attached to the connector. My document template markup currently looks like this
package >
{Pkg.Name}
{Pkg.Notes}
diagram >
{Diagram.Name}
{Diagram.Notes}
{Diagram.DiagramImg}
{Diagram.Figure}
element >
{Element.Name}
{Element.Notes}
< element
Uses/Integrations/Roles
connector >
{Connector.Name}
Protocol : {Connector.Alias}
Description : {Connector.Notes}
< connector
< diagram
< package
And I'd really like to put sourcename > destinationname above{Connector.Name}
motivatedgorilla
« Reply #3 on: February 19, 2014, 12:41:53 pm »
If i understand you correctly you can display the source name and target name if you select Connector > Source > Element and Connector > Target > Element from the sections pane
« Last Edit: February 19, 2014, 12:42:23 pm by motivatedgorilla »
LeeD
« Reply #4 on: February 19, 2014, 01:06:23 pm »
That only works if you're directly outputting elements in a package rather than producing from a diagram.
Jacob Vos
« Reply #5 on: February 19, 2014, 05:22:51 pm »
I was able to insert information about connectors displayed on a diagram that was in another package than the elements displayed on it.
The sections I have selected:
- Package
-- Element
--- Connector
---- Source
----- Element
---- Target
----- Element
-- Diagram
--- Element
--- Connector
I am still not getting the info and lay-out I want to get, but hopefully it helps you.
