Author Topic: RaQuest and reports  (Read 4337 times)
Emiliano
  • if you want, you can !!!
RaQuest and reports
« on: July 01, 2009, 09:50:57 am »
hi all,
it is possible to include the relationship map created with raquest in a report created with enterprise architect automatiically ?
umesan
Re: RaQuest and reports
« Reply #1 on: July 03, 2009, 02:56:21 pm »
Currently RaQuest makes a temporary diagram under 'RaQuest / ##RaQuestInfo## / Work' Package to show the relationship map when user runs the command to show the map from the RaQuest window.
This diagram is not deleted by RaQuest, so you can include this diagram in the the RTF report by moving it to the same package with the requirement or as the child element of the requirement.
In the future, we will add an option that changes the location where this relationship map is made. By this change, you can include the relatioship map in RTF reports only by changing the RTF report template.
Does my answer help you?
Emiliano
« Reply #2 on: July 03, 2009, 07:34:51 pm »
With a big number of requirements, the operation of generate relationship map must be done automatically and insert in the correct package.
umesan
« Reply #3 on: July 06, 2009, 03:21:58 pm »
We will consider whether either of the following two can be created as an external tool.
Please give us time.
- Move a temporary diagram which is under `RaQuest / ##RaQuestInfo## / Work' package to correspondent requirement's child.
- Generate a relationship map for all requirements newly under the requirement.
umesan
« Reply #4 on: July 07, 2009, 06:51:05 pm »
We have made the following custom tool.
'Move all temporary diagrams (which are in the `RaQuest / ##RaQuestInfo## / Work' package) to correspondent requirements' child.'
URL to download: http://www.raquest.com/registered/downloads/MoveWorkDiagrams.exe
Usage: MoveWorkDiagrams.exe <target project .rqe file>
Please try it.
