Author Topic: Error on Attempting to Generate Sequence Diagram  (Read 4651 times)
philchudley
« on: February 27, 2014, 03:09:24 am »
Hi All
The Analyzer is not a feature I use often in EA, but a need has arisen
I have a .net exe the code for which I have reversed into EA and I am now attempting to create a sequence diagram form the execution of the application.
I have followed the Use Guide and the Tutorial on the Community Site, but as soon as the recording starts I receive the following error
[highlight]Failed to Load Common Language Runtime[/highlight]
It appears EA cannot find something, but what and how do I configure where EA should look for the Common Runtime?
Cheers
« Last Edit: February 27, 2014, 03:29:18 am by philchudley »
Models are great!
Nizam Mohamed
philchudley
Re: Error on Attempting to Generate Sequence Diagr
« Reply #2 on: February 27, 2014, 09:25:31 pm »
Thanks for your reply
I have tried both suggestions, creating the config and downloading the Script Debugger
Unfortunately still produces the same error dialog
Failed to Load Common Runtime
Just cannot seem to get the recording / sequence diagram to work
Tried all possible break points, Class Markup for Recording nothing seems to work
Thanks again for your suggestion
Models are great!
philchudley
« Reply #3 on: February 27, 2014, 10:26:03 pm »
Finally got this work, I tried a different C# app and started all over again success this time!
Models are great!
Nizam Mohamed
« Reply #4 on: February 28, 2014, 02:30:36 am »
Thats great, any particular difference between the two attempts that you reckon made it work??
