Author Topic: ea for reverse engineering js into flow chart  (Read 5792 times)
jyu
« on: February 09, 2014, 11:45:00 pm »
Hi
I need a tool to generate flow chart from the code I write in html5 + javascript + jquerymobile. I read enterprise architect is the right tool. How to use it for that purpose?
Re: ea for reverse engineering js into flow chart
« Reply #1 on: February 10, 2014, 03:20:18 am »
Hmm. What is a flow chart? If it's that what I guess: use Visio.
« Last Edit: February 10, 2014, 03:32:19 am by qwerty »
« Reply #2 on: February 25, 2014, 09:32:07 am »
A flow chart is a strategic model.
See page 9 of http://www.sparxsystems.com/downloads/quick/strategic_modeling_with_enterprise_architect.pdf.
Note also some caveats.
You would be hard pressed to find it in the EA help.
« Last Edit: February 25, 2014, 09:35:46 am by skiwi »
« Reply #3 on: February 25, 2014, 11:08:01 am »
I meant that a bit ironically ;-)
« Reply #4 on: February 25, 2014, 12:42:42 pm »
Who's to say I didn't.
and some 'bugs' (someone termed this salesware).
  • it is not possible to use the quick linker to link to or from the On Page Connector. This is a bug.
  • it is not possible to remove the stereo text from the Begin, End, and Decision names displayed in the diagram.This is a bug.
  • when using the quick linker a "connector" link is created without prompting for the type, except when the source is Process, DefinedProcess. This is a bug, there should not be a prompt
reported
« Reply #5 on: March 04, 2014, 09:54:12 am »
Useful information from support
Regarding the comments in the forum...
    >> It is not possible to use the quick linker to link to or from the On Page Connector.
  • Our developers have confirmed that this is a bug and it is logged to be fixed. As a workaround you can create these connectors via toolbox instead.
>> It is not possible to remove the stereo text from the Begin, End, and Decision names displayed in the diagram.
  • You can hide these labels by disabling the "Diagram | Properties > Elements | Show Element Stereotypes" option.
>> when using the quick linker a "connector" link is created without prompting for the type, except when the source is Process, DefinedProcess Source or target
  • It appears some types are inheriting common connectors. Our developers have confirmed that this is a bug also. As a workaround you can create these connectors via the toolbox.
