Author Topic: copy element with link in the project browser?  (Read 4288 times)
Rainer Hoerbe
« on: February 23, 2014, 06:30:53 am »
EA has a dialog to copy/paste elements from other packages into a diagram with a "as link" option, so that changes to the element propagated to all diagrams where the element is references.
I am looking for a similar behavior in the project browser, which would allow an element to occur in different views and packages. My rationale for this is that I am working with a different models in the same project: a generic one and a project-specific one. The latter inherits from the former, and I want to avoid redundant work if changes apply to both models. And reports for the specific model should be self-contained, without referencing the general model.
Is it possible to solve this with EA?
Re: copy element with link in the project browser?
« Reply #1 on: February 23, 2014, 10:13:22 am »
Check View/Model View. THat's probably what you're after.
Rainer Hoerbe
« Reply #2 on: March 01, 2014, 12:08:31 am »
(Not sure if I understand this. I am using views. But how can I have an element in 2 views without duplicating it?)
After some research I do understand. And with eaDocX 3.4 one can do document generation base on model views. I have to test this in detail, but it looks like that model views are the solution for my requirement.
Thanks, Rainer
« Last Edit: March 01, 2014, 02:19:37 am by rhoerbe »
Rainer Hoerbe
« Reply #3 on: March 06, 2014, 01:49:04 am »
Model views do the job in principle, but they have a too rigid hierarchy for larger models. The only level where one can add elements is the favorites folder. Also it is not possible to drag and drop a complete subtree.
Does anybody have an alternative?
