Author Topic: Iterate through tagged names and values  (Read 5142 times)
motivatedgorilla
« on: March 07, 2014, 10:58:15 am »
I am attempting to iterate through a set of tagged values for a given element however unable to execute the code as it displays the error an object is required. I'm probably doing something wrong however am unsure what
var theElement as EA.Element;
var tag as EA.TaggedValue;
theElement = Repository.GetElementByID(52)
for ( var i = 0 ; i < theElement.TaggedValues.Count ; i++ )
            thisTaggedValue = theElement.TaggedValues.GetAt(i);
            If (thisTaggedValue.ElementID == tag.ElementID)
                  Session.Output(tag.Value);
Re: Iterate through tagged names and values
« Reply #1 on: March 07, 2014, 11:24:46 am »
tag is declared and used but not given a value, thisTaggedValue is given a value but not declared, and you're missing a ; on line 3.
« Last Edit: March 07, 2014, 11:25:17 am by KP »
motivatedgorilla
« Reply #2 on: March 07, 2014, 11:29:45 am »
Can you give me an example of how i can assign a value to tag and what thisTaggedValue should be declared as?
« Reply #3 on: March 07, 2014, 11:38:30 am »
AFAICS you should declare
var thisTag as EA.TaggedValue;
Nizam Mohamed
« Reply #4 on: March 07, 2014, 02:25:58 pm »
Please refer to VBScript / JScript Element Extras Example (Tools->Scripting) in EA to see how tagged values are iterated through.
Code excerpt below
           // Add a new tag
            var tags as EA.Collection;
            tags = theElement.TaggedValues;
            var newTag as EA.TaggedValue;
            newTag = tags.AddNew( "MyTag", "Number" );
            newTag.Update();
            tags.Refresh();
            Session.Output( "    Added new Tag: " + newTag.Name );
            newTag = null;
            // List all element tag
            for ( var i = 0 ; i < tags.Count ; i++ )
                  var currentTag as EA.TaggedValue;
                  currentTag = tags.GetAt( i );
                  Session.Output( "    Tag Value: " + currentTag.Name );
                  // Delete the tagged value that we just added
                  if ( currentTag.Name == "MyTag" )
                        tags.DeleteAt( i, false );
                        Session.Output( "    Deleted Tag: " + currentTag.Name );
