Author Topic: Export to Excel  (Read 8634 times)
michelreap
Export to Excel
« on: March 11, 2014, 11:54:13 pm »
I have both a Data Model (with tables and attributes, and foreign keys) and a Class Model (with classes with operations and attributes) diagrams.
Is it possible to export these diagrams to a Excel compatible format so I have all the attributes and operation in a table?
I tried the Export to CSV option but this only exports the table names and class names, not the inner attributes.
Robert Sheridan
Re: Export to Excel
« Reply #1 on: March 11, 2014, 11:59:16 pm »
Yes you can.  You can do it with VBA from a macro in Excel using the Sparx EA API.  There is a spreadsheet put together by Geert on the community site which you can use as a starter, I think it is for upload but you can use it to understand the API and create extract routines.
Nizam Mohamed
Re: Export to Excel
« Reply #2 on: March 12, 2014, 12:11:49 am »
Have you considered creating a doc template to render out your classes / attributes in the table format you expect in excel and then translating (copying / pasting) the generated document contents in an excel doc?
IMHO, this is way simpler than trying to do it yourselves with code.
michelreap
Re: Export to Excel
« Reply #3 on: March 12, 2014, 01:08:42 am »
How would you do that?
I will take a look at the mentioned Spreadsheet, see If I can get something out of it. Thanks.
Re: Export to Excel
« Reply #4 on: March 12, 2014, 04:09:25 am »
Try Diagram/Show as/List.
You can copy paste that.
Nizam Mohamed
Re: Export to Excel
« Reply #5 on: March 12, 2014, 02:54:26 pm »
Please have a look at rendering a normal table in rtf document, with appropriate fields.
If you are still finding any difficulty, share your sample excel table structure, i'll try to share the corresponding rtf template
Re: Export to Excel
« Reply #6 on: March 12, 2014, 05:55:03 pm »
I think the quickest, most flexible way is to create an SQL search that returns exactly the fields you are interested in.
Then copy/past the results in a text file and open it with excel as csv.
Writing an actual export function to excel isn't really complicated either, but it requires a bit of work.
I have this class called ExcelConnector that has this constructor:
/// <summary>
/// Creates a new connector and opens the document given by the document path.
/// </summary>
/// <param name="documentPath">the excel file path to open</param>
/// <param name="sheetName">the name of the sheet to open</param>
/// <param name="newDocument">if true then a new document will be created based on the template in the given documentpath. If false then the docuemnt in the path is opened</param>
public ExcelConnector(string documentPath,string sheetName,bool newDocument)
      if (newDocument)
            excelDocument = excelApp.Workbooks.Add(documentPath);
      else
            filePath = documentPath;
            excelDocument = excelApp.Workbooks.Open(documentPath, Type.Missing, Type.Missing, Type.Missing, Type.Missing, Type.Missing, Type.Missing, Type.Missing, Type.Missing, Type.Missing, Type.Missing, Type.Missing, Type.Missing, Type.Missing, Type.Missing);
      sheet = (Worksheet)excelDocument.Worksheets.get_Item(sheetName);
Now when I want to write something into the excel file I create a two dimensional string array and call this operation:
/// <summary>
/// write the contents to the excel sheet starting at the given row
/// </summary>
/// <param name="contents">the context to write</param>
/// <param name="beginrow">the row to start from</param>
public void write(object[,] contents, int beginrow)
      //get the exact range where the contents should be placed
      Range targetRange = sheet.get_Range(sheet.Cells[beginrow, 1], sheet.Cells[contents.GetUpperBound(0)+1 + beginrow-1, contents.GetUpperBound(1)+1]);
      targetRange.Value2 = contents;
Then to save I call
/// <summary>
/// save the document to the given savePath
/// </summary>
/// <param name="savePath"></param>
public void Save(string savePath)
      excelApp.DisplayAlerts = false; //avoid a file exists do you really want to overwrite dialog
      excelDocument.SaveAs(savePath, XlFileFormat.xlOpenXMLWorkbookMacroEnabled, Type.Missing, Type.Missing, Type.Missing, Type.Missing, XlSaveAsAccessMode.xlExclusive, Type.Missing, Type.Missing, Type.Missing, Type.Missing, Type.Missing);
      excelApp.DisplayAlerts = true; //turn it back on
Enjoy  :)
