Author Topic: Diagram Options  (Read 6379 times)
Doug Blake
Diagram Options
« on: March 31, 2014, 10:48:05 pm »
I have a project with over 700 diagrams. Is there a way to set default values for the items in the diagram properties dialogue instead of having to set the options for each diagram?
I am particularly interested in
  • Use Alias if Available
  • Show Namespace
DGB Using 12.0.1214 / eaDocX 3.6.2.1 / MSSQL / TFS / Windows 7 / IE11
philchudley
Re: Diagram Options
« Reply #1 on: March 31, 2014, 10:58:27 pm »
Hi Doug
I believe this is possible with a script, I am off site at the moment, but will have a go tomorrow and post the script here
Best regards
Phil
Models are great!
Re: Diagram Options
« Reply #2 on: March 31, 2014, 11:13:30 pm »
Doug you probably can using the template package.
Re: Diagram Options
« Reply #3 on: March 31, 2014, 11:14:59 pm »
Hi Doug
Best regards
Phil
A script can take care of the existing diagrams, the template package can be used to set the default value for new diagrams.
Doug Blake
Re: Diagram Options
« Reply #4 on: April 01, 2014, 12:13:13 am »
Hi Doug
Best regards
Phil
Well that's damn decent of you Phil. I find the problem with all this scripting is that it takes focus off the job in hand, so we are reluctant to get into it. It may be something we have no choice but to embrace, but we have resisted so far ...
Nizam Mohamed
Re: Diagram Options
« Reply #5 on: April 01, 2014, 12:39:58 am »
Simple VB Script to update diagram status across the model
option explicit
!INC Local Scripts.EAConstants-VBScript
' Iterates through an EAP file using recursion.
sub BatchEditDiagrams()
      ' Show the script output window
      Repository.EnsureOutputVisible "Script"
      ' Iterate through all models in the project
      dim currentModel as EA.Package
      for each currentModel in Repository.Models
            ' Recursively process this package
            ParsePackage currentModel
      next
      Session.Output ("DiagramIDs" & sDiagramIDs)
      Session.Output( "Done!" )
end sub
sub ParsePackage (thePackage )
      ' Cast thePackage to EA.Package so we get intellisense
      dim currentPackage as EA.Package
      set currentPackage = thePackage
      ' Add the current package's name to the list
      Session.Output( indent & currentPackage.Name & " (PackageID=" & currentPackage.PackageID & ")" )
      ' Dump the elements this package contains
      EditDiagramProperties currentPackage
      ' Recursively process any child packages
      dim childPackage as EA.Package
      for each childPackage in currentPackage.Packages
            ParsePackage childPackage
      next
end sub
sub EditDiagramProperties ( thePackage )
      ' Iterate through all elements and add them to the list
      dim currDiagram as EA.Diagram
      for each currDiagram in currentPackage.Diagrams
            Session.Output ( "Current Namespace Status" & currDiagram.HighlightImports & "Current Style" & currDiagram.ExtendedStyle)
            'Set Namespace visibility
            currDiagram.HighlightImports = 1
            'Set UseAlias
            if currDiagram.ExtendedStyle = "" Then
                  currDiagram.ExtendedStyle = "HideRel=0;ShowTags=0;ShowReqs=0;ShowCons=0;OpParams=1;ShowSN=0;ScalePI=0;PPgs.cx=1;PPgs.cy=1;PSize=9;ShowIcons=1;SuppCN=0;HideProps=0;HideParents=0;UseAlias=1;HideAtts=0;HideOps=0;HideStereo=0;HideEStereo=0;FormName=;"
            else
                  currDiagram.ExtendedStyle = Replace(currDiagram.ExtendedStyle,"UseAlias=0","UseAlias=1")
            End If
            currDiagram.Update
            Session.Output ( "New Namespace Status" & currDiagram.HighlightImports & "New Style" & currDiagram.ExtendedStyle)
      next
end sub
BatchEditDiagrams
« Last Edit: April 01, 2014, 12:58:03 am by nizammohamed »
Nizam Mohamed
Re: Diagram Options
« Reply #6 on: April 01, 2014, 12:41:11 am »
Script to update diagrams under a particular package
option explicit
' NOTE: Requires a package to be selected in the Project Browser
sub EditPackageDiagrams()
      ' Get the currently selected package in the tree to work on
      dim thePackage as EA.Package
      set thePackage = Repository.GetTreeSelectedPackage()
      if not thePackage is nothing and thePackage.ParentID <> 0 then
                  Session.Output ( "Current Namespace Status - " & currDiagram.HighlightImports & "Current Style" & currDiagram.ExtendedStyle)
                  'Set UseAlias
                  else
                  End If
                  currDiagram.Update
                  Session.Output ( "New Namespace Status - " & currDiagram.HighlightImports & "New Style" & currDiagram.ExtendedStyle)
            next
      else
            ' No package selected in the tree
            MsgBox( "This script requires a package to be selected in the Project Browser." & vbCrLf & _
                  "Please select a package in the Project Browser and try again." )
      end if
end sub
EditPackageDiagrams
« Last Edit: April 01, 2014, 12:58:25 am by nizammohamed »
Nizam Mohamed
Re: Diagram Options
« Reply #7 on: April 01, 2014, 12:42:59 am »
Request you to please try the script in a test model prior to trying in the actual model.
Also, whilst it may be time consuming, i'd request you to go with updating individual packages, rather than bulk model edit.
(Also start in a test model)
NB - I haven't tested this in all DBs, works ok in EAP
