Author Topic: Auto-Generating Reports with Use Case Scenarios  (Read 2466 times)
Brian L
« on: April 03, 2014, 08:18:36 am »
I am currently using the Document Generator class to insert use case scenarios into a PDF document.  The generated document lists the scenarios in alphabetical order.  I want to list the scenarios based on Path Type.  Other than having to loop through the scenarios myself, I wanted to know if there was a way to turn off the alphabetization and have the Basic Path list before the Alternate or Exception paths.
Thank you,
Brian
