Author Topic: how do i modyfi namespace genration in cpp  (Read 4768 times)
Martin Brndstatter
« on: April 07, 2014, 10:56:17 pm »
hello,
When i genrate c++ code from diagram i get this code in cpp
using namespace0::namespace1::namespace2
i would like to have it more like this :
namespace0 {
  namesapce1 {
    namesapce2 {
I am sure it can be achived by modifying the templamlates somehow.
I tried to mess around the templates but i failed ...
Can you help me with this ?
Martin
Nizam Mohamed
Re: how do i modyfi namespace genration in cpp
« Reply #1 on: April 08, 2014, 02:43:12 am »
Try changing C++ Code option. Tools-> Options-> Source Code Engineering -> C++ -> Generate Namespace
« Reply #2 on: April 08, 2014, 08:43:11 am »
Tools | Source Code Generation  Templates.
Select C++ in the language.
Copy the Namespace [Body/Declaration] templates into the Namespace [Body/Declaration] Impl templates. Adding Impl to the templates each is calling.
Martin Brndstatter
« Reply #3 on: April 10, 2014, 12:07:41 am »
ola,
I tried that and it works . Thanx for help .
but the
is still present in cpp . Can i get rid of that too ?
« Reply #4 on: April 10, 2014, 09:15:44 am »
I think it's generated from the Import Section Impl template. Unfortunately it looks like it's part of the fileHeaders macro. You can't define the contents of that directly, but you can list over imports and use classHeaders for the manually added ones. (I generally refer people to the PHP templates as an example of how this is done)
