Author Topic: Creating objects based on classes  (Read 3935 times)
Michel777
« on: April 15, 2014, 09:20:22 pm »
I need an object diagram with objects of the same classes. I have already created a class.
1) How to create an object based on that class ? My workaround: to create an object an then to cast it with "instant classifier"
2) After classifying are all the calls attribute hidden, although:
a) the class atrributes are public
b) feature visibilty (for object) : all the checkboxes were set.
Thanks a lot in advance,
Michel
Re: Creating objects based on classes
« Reply #1 on: April 15, 2014, 10:03:05 pm »
Just ctrl-drag the class on a diagram. You will be asked how to copy. Choose Instance. You can set that as default (it's a bit buried in the dialogue like many things).
Michel777
« Reply #2 on: April 15, 2014, 10:06:53 pm »
The only thing is missing in the tool: advisor named qwerty
Michel777
« Reply #3 on: April 15, 2014, 10:11:54 pm »
What about question 2) ?
Nizam Mohamed
« Reply #4 on: April 15, 2014, 10:51:00 pm »
You've to set runtime value for the attributes to display them in object diagram. Check http://www.sparxsystems.com/enterprise_architect_user_guide/10/standard_uml_models/runtimestate.html
