Author Topic: create keyboard shortcut for line style  (Read 11297 times)
drategon
« on: January 02, 2014, 08:56:59 pm »
I can't find anywhere in the customized keyboard shortchut for line style.
I woud like to create shortcut for orthogonal square.
any idea?
drategon
Re: create keyboard shortcut for line style
« Reply #2 on: January 02, 2014, 09:39:25 pm »
Thanks for response. installed the addon. But, can't find anything to set line style from the addon or create shortcut it.
btw, do u know where to trigger record macro?
« Last Edit: January 02, 2014, 09:44:32 pm by drategon »
Helmut Ortmann
« Reply #3 on: January 02, 2014, 10:30:51 pm »
Click on, Extensions, Add-in Window.
You may start the addin window by:
- Extensions
- ho_tools
- show window
If you have any question, advice or problem don't hesitate to contact me.
Helmut
drategon
« Reply #4 on: January 02, 2014, 11:06:51 pm »
Thanks for your response Helmut. but, nothing happens after i've clicked show window. any steps?
Do you have any help files or website for guide or tips?
« Last Edit: January 02, 2014, 11:20:20 pm by drategon »
« Reply #5 on: January 02, 2014, 11:43:32 pm »
Have you done the first step?
drategon
« Reply #6 on: January 03, 2014, 12:16:34 am »
oh... now i see... thanks now i can use line style directly.
But show windows still nothing happen
Helmut Ortmann
« Reply #7 on: January 03, 2014, 12:17:42 am »
@Geert Thanks a lot.
In
https://dl.dropboxusercontent.com/u/66337741/ho_Tools/ho_Tools.zip
you will find a new release with a fixed failure in settings and a new readme.txt file.
Helmut
drategon
« Reply #8 on: January 03, 2014, 12:36:23 am »
i'm using this(downloaded 1 hour ago from this link you shown, unless u just released a new version). show windows still nothing happen... do i need to set anything up before it willl show?
just suggestion, possible put keyboard shortcut for your buttons esp. line style?
« Last Edit: January 03, 2014, 12:38:01 am by drategon »
« Reply #9 on: January 03, 2014, 06:11:08 pm »
Unfortunately keyboard shortcuts are not supported by the EA addin system.
Helmut Ortmann
« Reply #10 on: January 03, 2014, 06:51:00 pm »
try uninstall addin. Install it. Restart EA.
Click on, Extensions, Add-in Window (is checked). Verify that this option is checked.
Than the Addin should appear as AddinWindow. At least you see an empty AddinWindow.
Note: You see an empty AddinWindow if no addin using this windows is installed. This is EA functionalty
Good luck,
Helmut
drategon
« Reply #11 on: January 03, 2014, 10:17:41 pm »
rcoelho
« Reply #12 on: April 21, 2014, 09:14:15 am »
When execute EA I get error in Extensions->Manage Add-Ins:
Status: Error - The Windows Environment has stopped the addin from loading.
Could someone help me with this trouble?
Thanks very much
« Reply #13 on: April 22, 2014, 04:50:50 pm »
Sometimes dll are being locked when they are downloaded from the internet.
Try to right click on the dll and see what options you have.
