Author Topic: EA - XMI Exports  (Read 4000 times)
youri
EA - XMI Exports
« on: April 30, 2014, 11:36:09 pm »
Hi there EA Users,
When using the diagram data from the archi ea xmi export then coordinates are a bit of..
See image:
The red 'blocks' are read from the XMI file (see code below):
<element geometry="Left=649;Top=118;Right=739;Bottom=188;imgL=649;imgT=118;imgR=739;imgB=188;" subject="EAID_3AC21F7C_3792_41ab_8064_E5C4630C7C5A" seqno="1" style="DUID=A71E2B56;HideIcon=0;"/>
The block uses the attributes: Left, Top, Right, Bottom (same as imgL ect.).
Is there some workaround inside EA to fix this problem?
Re: EA - XMI Exports
« Reply #1 on: May 01, 2014, 08:55:30 am »
The coordinates listed aren't meant to by the coordinates of a saved image.
What you are seeing would correspond to padding around the elements and extra space for the title image.
youri
« Reply #2 on: May 01, 2014, 04:16:48 pm »
Hi, and thanks for your reply.
Are the padding values set in the XMI export?
« Reply #3 on: May 01, 2014, 05:16:17 pm »
No, the purpose of the XMI is to provide information for round-trip. Not to document what you are seeing in a saved image. It's also not that simple because the image may or may not contain a diagram frame.
