Author Topic: Sequence diagram with Java Script  (Read 5732 times)
KvThiel
« on: May 13, 2014, 05:05:31 pm »
During a research about using the simulation in behavior diagrams I discovered 3 topics in the learning center in simulation&prototyping video on the Sparx site. These topics are "Sequence diagram with Javascript 1, 2 & 3, in the dynamic simulation chapter under simulation. When I tried to find these topics in my Enterprise Architect it seems they aren't in the learning center.
Could someone help me, do I have to update my learning center in some way or could someone send me the information about these topics ?
Kind regards,
KvThiel
RoyC
  • Read The Help!
Re: Sequence diagram with Java Script
« Reply #1 on: May 14, 2014, 09:09:02 am »
What version of EA are you using? In version 11, the method of accessing the Learning Center has changed slightly to a breadcrumb trail. So, you press Alt+F1 and, in the ribbon at the top of the Learning Center window click on the black drop-down arrows to expand and select:
Enterprise Architect > Simulation > Dynamic Simulation > Sequence with JavaScript 1 (or Sequence with JavaScript 2, or Sequence with JavaScript 3)
These options display Learning Center topics with the titles Automating a Sequence Diagram with JavaScript, Automating a Sequence Diagram with JavaScript 2, and Automating a Sequence Diagram with JavaScript 3.
In earlier releases of EA, I don't think that the selection path, options and titles are radically different.
Best Regards, Roy
KvThiel
« Reply #2 on: May 21, 2014, 09:31:10 pm »
I'm using version 10.0.1000, but in my learning center I can't find these topics. The only topics I can see are:
-State Machine with Javascript 1;
-State Machine with Javascript 2;
-Activity with Javascript 1;
-Activity with Javascript 2;
and finally,
- Debugging Simulations.
So is it possible to find these topics somewhere else? or could you send me more information about this? Because I need it for sending commands from one objects state machine to another objects state machine and return attribute-values back from the other object.
And I can't find any information about this. Could you help me with this?
« Reply #3 on: May 22, 2014, 08:56:15 am »
Well that's your answer. V10 wasn't able to dynamically simulate sequence diagrams with Javascript. That's why the topics are missing in your version.
