Author Topic: EA Installation - EADDS, TOGAF and ZACHMAN Add-in  (Read 5186 times)
aguevara
« on: May 14, 2014, 04:55:22 am »
As a result of getting a new laptop, I just installed Enterprise Architect 11 on my new laptop and installed several Add-Ins including EADDS, TOGAF and ZACHMAN. This process worked in my previous laptop, but in the new one, I am getting the following when I first initialize EA and open an existing model file.
- EADDS - BAD
- TOGAF and ZACHMAN - Cannot create xml document
Can you please chime in if you have any suggestions? thanks in advance.
Angelo
RoyC
  • Read The Help!
Re: EA Installation - EADDS, TOGAF and ZACHMAN Add
« Reply #1 on: May 14, 2014, 08:54:37 am »
For EA DDS, try using the new DDS installer released yesterday.  I'm not sure about the TOGAF and Zachman errors.
Best Regards, Roy
Monica Hockelberg
« Reply #2 on: May 20, 2014, 05:20:07 am »
I have the same error "cannot create xml document" after installing the TOGAF MDG.  Is there a fix for this?  Cannot load the MDG.
« Reply #3 on: May 22, 2014, 08:51:51 am »
A new version of each of those is still yet to bet distributed. The workaround is to manually install MSXML 4.
Monica Hockelberg
« Reply #4 on: May 23, 2014, 03:39:20 am »
Resolution from Sparx support:
This issue has been reported previously by another user also. Please try installing MSXML 4.0 and let us know if the error still occurs.
See: http://www.microsoft.com/en-au/download/details.aspx?id=15697
