Author Topic: Classifier's stereotype kept on instanciation  (Read 5857 times)
Guillaume
    • www.umlchannel.com
« on: June 10, 2014, 11:10:49 pm »
Is there any way to keep a class stereotype when creating an instance?
I have "client" and "server" stereotyped classes ; when creating a lifeline on a sequence diagram, can I tell EA to apply the class "client" or "server" stereotype on the instance/lifeline?
thanks
Guillaume
Re: Classifier's stereotype kept on instanciation
« Reply #1 on: June 11, 2014, 08:40:41 am »
You can assign it manually. However, I think that the stereotype from the classifier should be applied automatically. Looks like a bug to me, but I'm not that firm in the Superstructures. Maybe someone from Sparx could comment.
You should report that as bug anyway to see what they state officially.
« Reply #2 on: June 11, 2014, 09:33:59 am »
In general a stereotype on a classifier can't be applied to an instance because the instances are a different type of element.
However, in general the appearance of an instance is intended to match that of the classifier. (But with underlined name and : <classifier>) From the top of my head I don't know if the specification is explicit about displaying stereotypes from the classifier. It may be that it is appropriate to draw the stereotype even though it isn't explicitly defined.
« Reply #3 on: June 11, 2014, 07:27:16 pm »
At least EA is consistent in the way they apply that pattern. If you create an instance of a class the stereotype isn't copied too. Geert seems to be absent at the moment. He might have more insight in what OMG meant to happen in this case.
Guillaume
« Reply #4 on: June 11, 2014, 07:31:31 pm »
I think that copying the classifier's stereotype to its instance should be optional so this is more an enhancement request than a bug report.
e.g when creating an instance of a class, EA would prompt the option "Apply the classifier's stereotype to the instance" (default value : disabled).
Guillaume
« Reply #5 on: June 11, 2014, 07:35:55 pm »
I guess that way would make everyone happy. But on a short term that means you'd need to script that with an add-in listening to some of the OnPost events.
« Reply #6 on: June 12, 2014, 09:03:48 am »
It is possible to do this in a profile. Search the help for "_instanceType" for details.
In short, what you do is define a stereotype that extends "Class" (or any other classifier type), define a stereotype that extends either "Object" or "Part", and give the first stereotype an attribute "_instanceType" that names the second stereotype. There's more to it than that, but it's all in the help...
